Display error query: planar surface loading extents for panel-in-panel
andrew.fraserVBHU4
andrew.fraserVBHU4
If you create a panel within an already existing panel (e.g. perhaps part of the structure has changed or you made an error in defining a panel earlier in the modelling process), RSA doesn't modify the outline of the applied load correctly if the new panel is on the boundary of the original one.
Is this a display issue in RSA or is there something else I should be doing in making this sort of refinement?
It is easier to see in an example and with respect to the attached image:
  • Below the base panel is 10x10 and the load case is of a unit load.
  • I have then defined a sub panel within this of 2x2 in the middle and right models, the highlighted panels
  • In all instances the unit load is only applied to the panel it was assigned to as can also be verified by the reactions and from the loading table.
  • In the middle example the change to the loaded area is picked up by the outline, on the right most model it isn't.
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @andrew.fraserVBHU4
It is issue with load display when panels has common edge. Load is not applied to internal contour (unless it was defined for it - it can be checked in load table). Reactions are caclulated correctly.
Krzysztof Wasik
andrew.fraserVBHU4
Thank you Krzysztof.
It would be good if this graphical bug could be fixed as it makes checking a model rather difficult; having to use the load tables isn't likely to be a pragmatic option on complex models so being able to see it graphically is a good thing to have.
Ideally there would also be the built-in option to see area loading as a colour map as in some other software packages so it would be even clearer.
