Direct analysis method
HoshangMustafa
Advisor Advisor
Message 1 of 55
HoshangMustafa
Hi all
Please find the attached file.
This is to model Example 3.1 of AISC design guide 28. I modeled bracing as tension member as suggested in post 4 in this thread:
https://forums.autodesk.com/t5/robot-structural-analysis-forum/steel-bracing-advanced-bar-properties...
So, how to manage Direct analysis method with this model?
Description of Framing
All lateral load resistance is provided by the tension only rod bracing. The tension rods are assumed to be pin connected using a standard clevis and pin (see AISC Manual Tables 15-3 and 15-7). Beams within the braced frame are bolted into the column flanges using double angles (see AISC Manual Figure 13-2(a)). A single gusset plate connecting the tension rod is shop welded to the beam flange and field bolted to the column flange (see AISC Manual Figure 13-2(a)). All other columns outside the braced frames are leaning columns with simple beam-to-column connections.
Accepted solutions (3)
Replies (54)
Message 41 of 55
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @HoshangMustafa
Description in help regards bar members subjected to  tension, compression, shear and bending.
Krzysztof Wasik
Message 42 of 55
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @HoshangMustafa
I think that description in help regards bar members subjected to tension/compression, shear and bending.
Krzysztof Wasik
Message 43 of 55
HoshangMustafa
Thanks, @Krzysztof_Wasik
In my correct model in post 31, I tried using compatible node with rotation about Y axis by 26.6 degree for the members 14&15 after removing the tension only property from the members 14to17. But I couldn't manage the compatible node for them.
Message 44 of 55
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @HoshangMustafa
Share your file
Krzysztof Wasik
Message 45 of 55
HoshangMustafa
Hi @Krzysztof_Wasik
I'm sorry I didn't refer to the exact model in my last post.
Here is the model.
Message 46 of 55
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @HoshangMustafa
I do not see any compatibility defined in your model I could help with.
I do not know what kind of compatibility you would like to have.
Describe what kind of effect, regarding force transfer between bracings you would like to simulate.
Krzysztof Wasik
Message 47 of 55
HoshangMustafa
Hi @Krzysztof_Wasik
It's just for learning. Do whatever rotated compatible node in bars 14&15.
Message 48 of 55
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @HoshangMustafa
Attached you will find modified f ile
Krzysztof Wasik
Message 49 of 55
HoshangMustafa
Very appreciated.
Message 50 of 55
HoshangMustafa
Hi @Krzysztof_Wasik
May I describe compatibility node in words?
Say you have two intersecting bars and each bar is divided into two parts. Using compatible node at the intersection point for two parts of one bar and blocking any d.o.f will make the force diagram corresponding to this d.o.f continuous over these two parts of the said bar, regardless of the fact of its intersection with the other bar.
Message 51 of 55
HoshangMustafa
Hi @Krzysztof_Wasik
Sorry for spelling uncorrectly.
blocking should be read as unblocking.
force means (force or moment)
This means that this force or moment will not be distributed (transferred) to the other bar.
Message 52 of 55
HoshangMustafa
Hi @Krzysztof_Wasik
Is my interpretation correct?
Another thought.
We entered an angle for the rotated compatible node. Could it be entered as aligned with a member instead of inputting values? I think if the loads are large, inputting angles for the rotated compatible node maybe incorrect.
Message 53 of 55
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @HoshangMustafa
Your  interpretation is OK.
Angle while compatible nodes definition should be defined manually.
Krzysztof Wasik
Message 54 of 55
HoshangMustafa
Your response is highly appreciated and made better understanding of compatible node.
Message 55 of 55
abdirahmanabdulllahia
Community Visitor
Community Visitor
i have question related to leaning column when i wanna to make leaning column i should release my beams do release my beams rotation in direction Rz only or i should release all direction i wanna to use simple shear connection like shear tab
