Direct analysis method
HoshangMustafa
Advisor Advisor
Message 1 of 55
HoshangMustafa
Hi all
Please find the attached file.
This is to model Example 3.1 of AISC design guide 28. I modeled bracing as tension member as suggested in post 4 in this thread:
https://forums.autodesk.com/t5/robot-structural-analysis-forum/steel-bracing-advanced-bar-properties...
So, how to manage Direct analysis method with this model?
Description of Framing
All lateral load resistance is provided by the tension only rod bracing. The tension rods are assumed to be pin connected using a standard clevis and pin (see AISC Manual Tables 15-3 and 15-7). Beams within the braced frame are bolted into the column flanges using double angles (see AISC Manual Figure 13-2(a)). A single gusset plate connecting the tension rod is shop welded to the beam flange and field bolted to the column flange (see AISC Manual Figure 13-2(a)). All other columns outside the braced frames are leaning columns with simple beam-to-column connections.
Accepted solutions (3)
Replies (54)
Message 21 of 55
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @HoshangMustafa
Refer to this tutorial
Krzysztof Wasik
Message 22 of 55
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @HoshangMustafa
Krzysztof Wasik
Message 23 of 55
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @HoshangMustafa
You have to define ULS combinations for this model then you can run  run DAM analysis.
Refer to DAM analysis description
Krzysztof Wasik
Message 24 of 55
HoshangMustafa
Thanks, @Krzysztof_Wasik
I thought that you (and help topic) meant that the two intersecting continuous bars being not divided. But the tutorial states that (it is important that they are divided) (at 0:41).
Message 25 of 55
HoshangMustafa
Hi @Krzysztof_Wasik
I modeled a structure as shown on the tutorial . I applied the compatible node. I can't see the continuity in the My diagram. Can you verify why?
Message 26 of 55
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @HoshangMustafa
Compatibility is defined in global system of coordinates (not in local bar system as for releases). You have not released RY in compatibility definition.
Krzysztof Wasik
Message 27 of 55
HoshangMustafa
Hi @Krzysztof_Wasik
But in the tutorial , it included RY as blocked direction (@ 4:11).
Autodesk Robot [ENG] - compatible nodes [napisy PL] - wezły kompatybilne 4-11 screenshot.png
Message 28 of 55
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @HoshangMustafa
Your model is rotated by 90 degrees in comparing to model from tutorial. I have marked main beams directions in both models.
Krzysztof Wasik
Message 29 of 55
HoshangMustafa
I'm sorry for this mistake. Another question came into mind. What are practical cases for using compatible nodes structurally?
Message 30 of 55
Krzysztof_Wasik
Autodesk Support
Autodesk Support
HI @HoshangMustafa
Compatible nodes can be used when some degrees of freedom are released between two continuous elements.
Some examples:
- connection between continuous purlin and continuous rafter (when continuous bending moment should be obtained for purlin).
- connection between continuous primary and secondary elements in grillage structure (when continuous bending moment should be obtained for both members)
- connection between continuous bracing when connection with pin is used (as presented in message 17)
- it can apply to effect described in message 6, when continuous beam is connected with continuous column and only vertical force should be transferred to column (support by continuous column should be regarded as pinned support)
Krzysztof Wasik
Message 31 of 55
HoshangMustafa
I appreciate your help.
Please find the attached file. Am I modeling it correctly using compatible nodes?
Message 32 of 55
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @HoshangMustafa
It is defined correctly
Krzysztof Wasik
Message 33 of 55
HoshangMustafa
Thanks, @Krzysztof_Wasik for your patience. You've been very helpful.
Message 34 of 55
HoshangMustafa
Hi @Krzysztof_Wasik again.
But this message was about continuous beam and column.
Another thought came into mind.
How compatible node is defined for bracing since compatible node is defined in Global direction? For example defining compatible node for bracing in model posted in message 1.
Message 35 of 55
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @HoshangMustafa
This answer regarded your question from message 29
Krzysztof Wasik
Message 36 of 55
HoshangMustafa
Hi @Krzysztof_Wasik
Please follow the last paragraph in message 34, especially my concern is an example in the help file:
Robot Structural Analysis 2020 Help | Compatible nodes definition - example | Autodesk
Message 37 of 55
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @HoshangMustafa
Compatible nodes are defined in global system of coordinates, but if it is necessary you can define required angles (for each compatibility) so you can rotate them in respect to Z(alpha angle), Y(beta angle) and X(gamma angle ) global axis.
Krzysztof Wasik
Message 38 of 55
HoshangMustafa
Thanks @Krzysztof_Wasik
This is very helpful, especially rotating compatible nodes with respect to global axes. I'll try it.
If the bracing is defined using tension only bars, why should I use connection with pin?
Message 39 of 55
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @HoshangMustafa
I think that description in help does not regard tension only members.
Krzysztof Wasik
Message 40 of 55
HoshangMustafa
Hi @Krzysztof_Wasik
Aren't these members bracings? Isn't one member of the cross will be in tension and the other in compression?
If that description doesn't regard tension only members, what members does that description regard?
I wanted to try rotated compatible node for the bracing in my model, but without succeed. Can you help with this?
