Direct Analysis Method isnot working for 2D Frame
mustafahesenow
Advisor Advisor
Message 1 of 9
mustafahesenow
Hi Guys,
I think there is problem for DAM in 2D frame its not activated .
Is there a reason behind this ?
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
Replies (8)
Message 2 of 9
Hello Mustafa,
I try it in my computer and it works. I dont know the reason.
Message 3 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @mustafahesenow
My understanding is that it was based on the assumption that if he introduce the imperfection to the otherwise perfectly vertical column so that it increase bending then we cannot limit to the one plane only.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Message 4 of 9
mustafahesenow
Hi @Anonymous
Ohhhh Really why its not working with mine ? Could you attach screenshot ?
Mustafa Hesenow
LinkedIn
Message 5 of 9
mustafahesenow
Hi @Artur.Kosakowski
I think it should be implemented in both 3d and 2d as well . As you notice in the procedure of this method it makes study for each direction individual
and the imperfections are defined in this way by adding notional loads.
Mustafa Hesenow
LinkedIn
Message 6 of 9
joined.
Message 7 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @mustafahesenow
I will pass your request to the development team. For a moment please define your 2D model as a 3D frame model.
If one or more of these posts answered your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Artur Kosakowski
Message 8 of 9
mustafahesenow
Hi @Anonymous
Usually if you are working on 2D frame only X , Z directions are activated so you cant create load on Y direction .
What is seen in this picture that is it possible to add notional load on Y direction which totally wrong.
Mustafa Hesenow
LinkedIn
Message 9 of 9
You are absolutetly right, Mustafa..
