Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Difference between simple bar and beam
1 REPLY 1
1612 Views, 1 Reply
hey,
I want to design a steel structure elements on robot,
however i am getting confused by the member type between simple bar and beam.
Both give different results of ratio and one take into consideration lateral buckling the other no. for example bar 88 see attached dwg.
What should I use usually please can you help me.
http://www.filemail.com/d/kisbwnjvunyglqb
George
1 REPLY 1
Artur.Kosakowski
Defining member type for bar 88 should you consider which elements of the model you consider as prevent buckling and lateral buckling. If the slab is such restrain then you may set no LTB for the top flange and assume that it also prevents buckling of the beam in the horizontal direction. For buckling in the vertical direction for simply supported beam you usually assume 1.0 coefficient.
Artur Kosakowski
Technology Administrators
