diagrams for bars - truss
Message 1 of 8
hi there,
i got a question. In my model
https://www.dropbox.com/s/o1r0ps1j91xqo6j/results_skyline.rtd?dl=0
for Cases 8 to 61,  Forces Fx are shown as full compression for top part of truss,  plus   some compression  and then tension  for bottom part.  Is that logic?  I think bottom part should work for tension only, or im wrong? if not, what can be a problen in this model?
Replies (7)
Message 2 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Without bars  2to626By104 105to120By5 108to628By104 112to632By104 114to538By106 118   122to434By104 207to623By104 214to630By104 217to633By104 222 224 227to643By104   324to636By104 328 430 534 536 638 640 642 847to857 964to974  :
Rafal Gaweda
Message 3 of 8
Yes, it helps with diagrams. But i want to keep bottom chords  and cables, who are working for tension for reducing spread forces for collumns beacuse of truss self weight and applied loads.  Im seeking for solution of that.
Message 4 of 8
It also takes 30-60 min in calculations for my model with chords and cables. Any chances to reduce this big amount of time ?
Message 5 of 8
Rafacascudo
Try "tension only" bars instead of cables.
On Geometry/Additional atributes/advanced bar properties
Rafael Medeiros
Message 6 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Total time: 295 seconds (results-skyline.rtd + multithreaded solver)
Rafal Gaweda
Message 7 of 8
I did change cables to truss members. Also, I changed bottom chords releases with columns. Now calculation time reduced to ~10 mins, maybe less,  method - skyline. Thanks for help.
Message 8 of 8
issue was with cable force F0, i dit not change default parameter which was 100kN
