Hi all,
I have a problem with detailed correction in Robot. I find this tool very useful and very powerful. Unfortunately I can not use the "selected construction lines" option that always appears grayed (see picture)
Does anyone know how to use it?.
Of course I tried to select the construction lines.
Currently this option will use all defined structural axes as the planes to which adjust the model. In case you want to adjust the model to only one of the planes use 'to the plane' instead and indicate it by clicking on 3 points that define this plane instead.
hi Artur,
It seems to me that aligning respect to a single plan or a number of construction lines is not the same thing.
Selecting a certain number of construction lines means to align beams and panels along lines rather than planes.
However ... the otion is always grayed because it is not implemented yet?
Depends on the decision you make: intersections, axes or planes defined by the system of orthogonal structural axes (see the attached picture).
Correct.
