design ribs in hollow block slab
MahmoudAlcholbec
MahmoudAlcholbec
when we design ribs in hollow block slab as beam T
from the chart My we see My value start from 0.00 and end at 4.7 (photo 1) but as a result, we see the bar position, reinforcement start from 0.4 and end at 4.3 (photo 2)
Can we request from the Robot ( required reinforcement of RC Beam) design to start from 0.00 and end at 4.7?
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @MahmoudAlcholbec
Probably you are using default RC beam setting with span calculated between support faces.
Change setting to In axes.
Krzysztof Wasik
MahmoudAlcholbec
Thank you @Krzysztof_Wasik
yes, when we change as you said the results beginning and end are changing.solved.png
