Design of core wall by using robot
Message 1 of 17
Kindly, I need the methodolgy of using robot for design of core wall
Replies (16)
Message 2 of 17
Artur.Kosakowski
Autodesk Support
Autodesk Support
Assuming you want to calculate reinforcement there are two options:
1. Use RC Panels Reinforcement module
2. Use RC Wall reinforcement module (currently available codes are BAEL, EC2 and ACI).
Artur Kosakowski
Message 3 of 17
stroxy
Is shear wall design for EC2 now enabled in Robot?
Message 4 of 17
Artur.Kosakowski
Autodesk Support
Autodesk Support
Yes, it is for French NAD.
Artur Kosakowski
Message 5 of 17
saclovitzky
Hello Artur
"Assuming you want to calculate reinforcement there are two options:
   - How will I view the reinforcement maps for the walls?
2. Use RC Wall reinforcement module (currently available codes are BAEL, EC2 and ACI)."
Message 6 of 17
Rafal.Gaweda
Autodesk Support
Autodesk Support
RAmon
The same as for panels \ slabs required reinforcement module \ maps.
Rafal Gaweda
Message 7 of 17
stroxy
I think I might have asked this question before, but does one  group the core walls by stories or is the core wall group the whole stack (i.e. over multiplie stories)?
Message 8 of 17
Rafal.Gaweda
Autodesk Support
Autodesk Support
As far as I understood you correctly - define core walls as a whole stack (but each wall not as a one panel - several panels from story to story level)
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Core-walls-results/m-p/3446505/highlight/tru...
Rafal Gaweda
Message 9 of 17
stroxy
Thanks, If I understand correctly, the core wall is defined by selecting all the panels making up the core wall (eg. C-, or L- shaped) over multiple levels and defining all these as 1 core wall
Message 10 of 17
Rafal.Gaweda
Autodesk Support
Autodesk Support
Exactly !
Rafal Gaweda
Message 11 of 17
there I intent to use ROBOT result to deign core wall manually.
my question:
about the value of the moment WMX &WMY based in which coordinate should be considered.
OR shall I considered big value for major axis for the wall?
as I got some un explanation value
Message 12 of 17
Is there a way in robot to provide reinforcement for a whole corewall, not for each wall of it separately?
Message 13 of 17
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
No, there is no such option in Robot.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Message 14 of 17
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
The results for core walls are in the global coordinate system.
If one or more of these posts answered your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Artur Kosakowski
Message 15 of 17
DaneRei.Abranilla
Hello!
ROBOT isn't giving me reactions for this core wall. It is the only core wall group where there's no result shown.
Message 16 of 17
Krzysztof_Wasik
Autodesk Support
Autodesk Support
HI @DaneRei.Abranilla
Share zipped model for verification.
Krzysztof Wasik
Message 17 of 17
DaneRei.Abranilla
Hello!
I think this has been resolved. What I did was attach the core wall to the slab above by reducing the opening size so3.JPG there's a very slim wall pier connecting the two.
