Design of base plate of steel column
tekno.structures
tekno.structures
When designing a steel connection for the base plate of a steel column using the steel connections module in RSA and specifically for the concrete cone pull-out checking, are the reinforcement bars of the concrete footing/ground beam/column pier taken into consideration?
What I mean is that, the anchors inside a foundation are almost always surrounded by steel reinforcement therefore where the cone pull-out failure plane is formed a steel bar may be passing through it which gives more resistance against cone pull-out (tension) or breaking of concrete edge (shear).
tekno.structures
ACI 318-11 refers to this in the below pages
Anchors in Reinforced Slabs.pngAnchors in Reinforced Slabs 2.pngAnchors in Reinforced Slabs 3.png
Stephane.kapetanovic
hi @tekno.structures
Note that Eurocode is available
https://www.boutique.afnor.org/en-gb/standard/nf-en-19924/eurocode-2-design-of-concrete-structures-p...
The eurocode could advantageously replace the current CEB checks carried out using the steel connection module.
Remember your posts at following links :
https://forums.autodesk.com/t5/robot-structural-analysis-forum/fixed-base-column-ceb-design-guide-lo...
https://forums.autodesk.com/t5/robot-structural-analysis-forum/seismic-design-of-steel-connections/m...
We can only hope that EN 1992-4:2018 is part of the next development.
Note that the draft standard prEN 1992-4:2013 (Eurocode 2: Design of concrete structures - Part 4: Design of
fastenings for use in concrete) is notified with CEB_96 by CNC2M in th following document :
https://www.bncm.fr/public/uploads/2020/04/CNC2M-N0175-REC-Dimensionnement-Assemblages-NF-EN-1993-1-...
Best regards
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
new publication - in French
Fixation et ancrage des ossatures métalliques dans le béton – Conception et dimensionnement
