Depressions in slabs
pevelor
pevelor
Hi
I have a slab with depressions, and I am wondering the correct way of modelling this.
What I have done is the following:
1. Define contour of the main slab.
2. Assign thickness to the main slab
undefined
3. Define a new contour inside the first slab for the depression.
4. Assign thickness for the depression
I am afraid the stiffness might be incorrect if the main slab does not have openings where I assign new panels (depressions). In other words, will the stiffness be correct?
Regards
Peder
Artur.Kosakowski
Autodesk Support
Autodesk Support
Yes, it will.
Artur Kosakowski
pevelor
Thats what I figured. So in other words, when I create a new panel inside another panel it will create an opening in the main panel....
The reason I got concerned I because of the values obtained in rc design
Could you explain why I get higher values where I have depressions? (All slabs have identical material)
undefined
Artur.Kosakowski
Autodesk Support
Autodesk Support
It will create a panel with elements of different thickness. If you create a contour then it will create an opening instead.
I'm sorry but having only the picture  I'm not able to figure out what you actually modeled. Please check values of displacements and internal forces first to understand the behavior of the structure (make sure that the model behaves as you wanted it to do). The reinforcement is just the secondary result so usually this is not the area you should start your investigation with.
BTW: I may be wrong but assuming that you have continues transfer of bending along the slab the same value should cause larger reinforcement in the part with the smaller thickness.
Artur Kosakowski
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
