delete section in user database
another problem I want to share it with you. After I defined a section by using section definition, I surprised that there is a mistake in the name of the section so I wanted to delete it .. I followed the instructions which have been published by Autodesk shown in the following link :
https://knowledge.autodesk.com/support/robot-structural-analysis-products/learn-explore/caas/sfdcart...
unfortunately, I couldn't find the mentioned table:
I didn't find a table, just incomprehensible letters and symbols. So pls anyone can advise me to fix that ??
Artur.Kosakowski
Autodesk Support
Autodesk Support
HI @Anonymous
It seems that you 'disregarded' the first step and instead of opening the Section Database browser you decided on editing the xml file. See this movie:
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
thank you so much Mr. Artur.Kosakowski. it was helpful to send this tutorial
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
I have also updated the article with the link to the above video so that it is easier to understand the listed steps. Please allow some time for its refreshing on the server before checking as it may take a bit Smiley Wink
Artur Kosakowski
michael.chan86XED
Hi @Artur.Kosakowski
