Hi all,
I'm currently working on a script that will remove all avaible supports that are defined in a project.(because it will be part of a bigger script that will run several times and everytime the supports will change.)
here is the list of the supports which are stored.
this is the error i get when running the script.(but labels are deleted, not always. sometimes 1 remains)
Warning: IronPythonEvaluator.EvaluateIronPythonScript operation failed.
Traceback (most recent call last):
File "<string>", line 28, in <module>
EnvironmentError: System.Runtime.InteropServices.COMException (0x80004005): Error HRESULT E_FAIL has been returned from a call to a COM component.
at Microsoft.Scripting.ComInterop.ComRuntimeHelpers.CheckThrowException(Int32 hresult, ExcepInfo& excepInfo, UInt32 argErr, String message)
at CallSite.Target(Closure , CallSite , Object , Object )
at lambda_method(Closure , Object[] , StrongBox`1[] , InterpretedFrame )
at Microsoft.Scripting.Interpreter.Interpreter.Run(InterpretedFrame frame)
at Microsoft.Scripting.Interpreter.LightLambda.Run2[T0,T1,TRet](T0 arg0, T1 arg1)
at IronPython.Compiler.PythonScriptCode.RunWorker(CodeContext ctx)
at Microsoft.Scripting.Hosting.ScriptSource.Execute(ScriptScope scope)
at DSIronPython.IronPythonEvaluator.EvaluateIronPythonScript(String code, IList bindingNames, IList bindingValues)
this is the script which i use to delete the labels.
import clr
clr.AddReference('ProtoGeometry')
from Autodesk.DesignScript.Geometry import *
from System import Environment
user = Environment.GetFolderPath(Environment.SpecialFolder.ApplicationData)
clr.AddReferenceToFileAndPath(user +r"\Dynamo\Dynamo Core\1.3\packages\Structural Analysis for Dynamo\bin\RSA\Interop.RobotOM.dll")
from RobotOM import *
from System import Object
#The inputs to this node will be stored as a list in the IN variables.
start = IN[0]
application = RobotApplicationClass()
project = application.Project
structure = project.Structure
labels = structure.Labels
loads = structure.Cases
LabServ = IRobotLabelServer
LabServ = project.Structure.Labels
RNA = IRobotNamesArray
RNA = LabServ.GetAvailableNames(IRobotLabelType.I_LT_SUPPORT)
count = RNA.Count
for i in range(count+1)[::-1]:
LabServ.Delete(IRobotLabelType.I_LT_SUPPORT, RNA.Get(i))
OUT = "gedaan", countDoes anyone of you know where/what i'm doiing wrong to get this working without any errors?
Thanks in advance
Gr Edward.
PS: files are attached(robot with stored labels, and dynamo file). i'm working with dynamo studio.
