deflection check
deflection check
saraingenieur
deflection check
saraingenieur
HI
I need some help. I’m unable to perform the deflection check in Robot Structural Analysis when using the ANSI/AISC 360 code.
Does anyone know why RSA does not evaluate serviceability (deflection) with this design code, or how to enable it?
Thank you in advance.
khimpitou
there is no load case (SLS), Create Load combination (SLS) then try again
saraingenieur
Thank you
