Definition of Non linear spring function
SMVZWDPY
SMVZWDPY
Hi
im trying to define a non-linear spring function. When i import my discrete function values as a text file it seems like the program is changing the digits by a factor 1000?  See screen dump below , which illustrate the last 4 rows of data.
My input units are: mm and N. I can see i should use kN for the force, but it doesnt change that the input is multiplied by a factor 1000? Can somebody help?
Thank in advance!
mustafahesenow
Hi @SMVZWDPY
Could you please attach the text file of nonlinear spring in order to check it .
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
I´m trying to model the soil behavour using a nonLineal Spring (as showed above) for an anchored wall,
When I run the model a message of Warning appears, so I can´t finish the analysis. Could someone help me with it?
I attached some screenshoot.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Could you zip and attach the Robot model?
Artur Kosakowski
