Cut on shell results for envelop
c.saouridis
c.saouridis
I made some cuts along a path on shell elements and I asked for results on this cuts for an envelop of (8) seismic combinations. What is given seems to be the absolute maximum values along the path but we are missing the absolute minimum values (see attached image "Envelop.png").
However, among the 8 seismic combinations, there are some producing negative results (see attached image "Case 20006.png"). Why these negative results do not appear on the cut?
Thanks for your prompt reply.
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @c.saouridis
You can switch between top and bottom envelope using Component selection option.
Krzysztof Wasik
c.saouridis
Sorry, where can I find the "component selection option"?
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @c.saouridis
Refer to screenshot. Select component option is marked by red arrow
Krzysztof Wasik
c.saouridis
Thanks a lot. Solved
