Critical Bending Moment
Analysing the calculations of the critical bending moment for the same beam (assuming the same length but obtainingin it in different ways), I've noticed some issues I couldn't explain.
Let's assume a simply supported 16m long beam, with bracings every 4m.
- One bar with 16m.
Code parameters:
Lz=16m
Llt=4m (defined with bracings)
2. 4 bars, 4m each
Coed aprameters:
Lz=4m
Llt=Lz (Lcr=L0)
3. 4 bars, 4m each
Code Parameters:
Lz=16m
Llt=4m (Lcr=0.25xL0)
Runnig then calculations, we get to the following Critical moments (which I thought should be the same in every situation sicne de the critical length for bending is the same):
1.
2.
3.
As we can see, the first 2 situations lead to the same value of the critical moment, but the last one leads to a much smaller one. It seemes RSA is some how afecting the values of kz in the critical moment formulation, since the values of C1 and C2 are the same for all the cases.
Does anyone knows why this happens?
Thanks in advance.
