creation of panels in RSA with RSA API via Dynamo
Hi all
I'm trying to create a panel in RSA via Dynamo, by CreateContour and then assigning a thickness to the contour.
The problem is that the thickness will not be added to the contour in RSA, it is only the contour that is defined.
Someone who sees what's wrong in the kode that is laid down? (has it someting to do with the numbering of contour and Panels?)
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
See C# code which works well:
           RobotApplication r = new RobotApplication();
            int fn = r.Project.Structure.Objects.FreeNumber;
            RobotPointsArray pa = r.CmpntFactory.Create(IRobotComponentType.I_CT_POINTS_ARRAY);
            pa.SetSize(4);
            pa.Set(1, 0.0, 0.0, 0.0);
            pa.Set(2, 1.0, 0.0, 0.0);
            pa.Set(3, 1.0, 1.0, 0.0);
            pa.Set(4, 0.0, 1.0, 0.0);
            r.Project.Structure.Objects.CreateContour(fn, pa);
            RobotObjObject ro = (RobotObjObject)r.Project.Structure.Objects.Get(fn);
            ro.Main.Attribs.Meshed = 1;
            ro.Initialize();
            ro.SetLabel(IRobotLabelType.I_LT_PANEL_THICKNESS, "TH30_CONCR");
            ro.Update();
Maybe Your panel thickness does not exist yet (before applying) ?
Rafal Gaweda
Thanks for the quick reply! It works fine now Smiley Very Happy
How do i rewrite the line in C or VBA or C++
