Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Creating concrete and steel slabs
1 REPLY 1
Ferdissss
136 Views, 1 Reply
Hi!
In Robot Structural Analysis, I want to create a steel and a concrete wall/slab. I have heard that you can use contour to draw the area, and then change the thickness and material of it to what you want to create a concrete/steel wall. I tried this, but the mass of my structure and the deflection doesn't change, so I guess it is still a cladding? How do you then create a wall, can you only do it by changing the geometry to 'Building design', and choose wall?
1 REPLY 1
Rafacascudo
in reply to: Ferdissss
No.
On panel geometry dialog ,click on parameters button and then mark it to be a "panel" instead of "cladding" or "opening"
Rafael Medeiros
