Create Panel From FE Elements
chrismcc
chrismcc
I am using Robot 2018 and am not able to create panels from FE elements, i.e. split existing panels.  I have done this in previous versions, but am not able to go back and check previous versions.  Is there a bug in the current version?  I have watched the earlier videos for a refresher, but that did not help.
I selected the relevant FE elements through the PANEL dialogue box and then ADD, but no contour appears even after redraw.
Any ideas?
Thank you in advance.
Chrismcc
Rafacascudo
It´s working here. RSA 2018 with latest patch/hotfix
Rafael Medeiros
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @chrismcc
Could you attach your model and indicate the list of surface elements to create a panel from?
Artur Kosakowski
