Create contour points to slabs at slab/wall intersections
Hi all
I am in the process of modelling a multi-storey RC structure. I intend to mesh my 1st storey slab before applying loads and analysing the slab. I will then copy the structure up ‘n’ number of times to create my tower.
In order to create coherent meshing, I would like to create contour points on my floor slab at wall intersections.
Please see images attached for reference while I explain. My floor slab is a shell element which I defined using several contour points (all existing contour points are shown as blue). I have introduced openings to my slab for stair/lift cores. I would like to create new contour points (red) for coherent meshing purposes.
To do this I have selected the wall and slab and hit the intersect command, however this doesn’t introduce a new contour point. I have also tried selecting the wall edge and the slab and hit interest, but that doesn’t work either.
Can anyone suggest a solution please?
Many thanks,
Tommi
