Create a gap (Settlement) of supports through VBA
I have modeled the basement with another program and I need to transfer the movements from the basement to the superstructure.
The superstructure model is in ROBOT.
I collect the  reactions from Robot I impose them in the basement model as loads I run the basement model and then I collect the movement of the basement and I apply the movement as gap at the support.
Here is the code I use.
Set Label = robapp.Project.Structure.Labels.Create(I_LT_SUPPORT, "Support")
Set SupportData = Label.Data
SupportData.UX = .1154
SupportData.UY = .21
SupportData.UZ = .32
the code doesnt have a bug or anything like that but it doesnt work it doesnt create the gaps that I want in all x,y, z directions.
Does anyone know how to impose the movements through VBA at the supports?
Thanks in advance
Manos
The numbers are just random by the way in reality they are quite small
Rafal.Gaweda
Autodesk Support
Autodesk Support
Only as nonlinear function:
d1, k1,k2 should be correctly set
Dim Label As RobotLabel
Dim NSD As RobotNodeSupportData
Dim NLM As RobotNonlinearLinkMngr
Dim NL As RobotNonlinearLink
Set NL = RobApp.Project.Structure.Nodes.NonlinearLinks.Create("NonlinModel")
NL.ModelType = I_NLMT_FORCE_DISPLACEMENT
NL.SetCurveType I_NLCT_B_LINEAR
Dim ANL As RobotNonlinearLinkParamsBLinear
Set ANL = NL.GetParams
ANL.d1 = 50
ANL.K1 = 200
ANL.K2 = 0
NL.SetParams ANL
Set Label = RobApp.Project.Structure.Labels.Create(I_LT_SUPPORT, "NONLIN")
Set NSD = Label.Data
Set NLM = NSD.NonlinearModel
NLM.Set I_DOF_UX, "NonlinModel"
RobApp.Project.Structure.Labels.Store Label
Rafal Gaweda
Rafal thanks I will try it and ask further questions in case I have
