Cracking
Cracking
Cracking
I have model which seems to work okay for main analysis, but I am having a problem with the reinforcement design particularly in regard to cracking (which gives nonsensical results). I am not getting any warnings, and am confident there are no geometrical issues. Have I missed something basic?
Model attached.
Best
Jack
Artur.Kosakowski
Autodesk Support
Autodesk Support
Could you attach a screen capture which illustrates what you named as nonsensical results and tell what you would expect to get instead?
Artur Kosakowski
Hi Artur,
I'm expecting some cracks between 0 and 0.2 mm, the attached screenshot has a scale going up to 1000000mm, although my results make much more sense in other directions.
Jack
Artur.Kosakowski
Autodesk Support
Autodesk Support
When the cracks are 0 everywhere the scale is displayed like this (from -1000000 to +1000000) as the re is no top and bottom value determined. You may check these values in the reinforcement result table.
Artur Kosakowski
