Corus Sections deleted from user Database
I am unable to use Corus members in the Section Selection. The database is blank and offers no sections to choose from.
(ROBOT 2016)
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
I'm attaching the original database in case yours get corrupted.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
rsousa_
I don't have your version, but recommend checking this location, or similar, C:\Program Files\Common Files\Autodesk Shared\Structural\Common Data\Data\Prof. Check CorusPro.mdb file with access and see what you have inside.
If is empty, replace with the following and see if it solves your problem
https://we.tl/BR1qdgBgYH
regards
