Correcting linear two point load
pevelor
pevelor
Hi
I recieved a file with linear loads applied to an edge using the 'two-point' option instead 'linear on edge'.
After verification, I get a warning which states that linear load is not applied to any element.
I see where the load is in the 3d view because of the blueish line but I cannot seem to identify it in the loadtable.
Is it possible to highlight it in the loadtable?
Whats the best way of correction this problem?
Regards
Peder
Artur.Kosakowski
Autodesk Support
Autodesk Support
I would try to use the load properties after indicating the load graphically (move the cursor till the moment the load is highlighted and RMB)
Artur Kosakowski
pevelor
Thanks. That will workSmiley Happy
