Correct modal analysis
vise92
vise92
Hello everyone! How do I know if the results I have found for the modal analysis (frequency and period) are correct? The structure is a polygonal pole 12 meters high with a 3.5 meter high flagpole on top (see attached image). For the modal analysis I made these choices (see attached images) and on top of the polygonal pole I added an additional mass of 4000 N (condition number 4). But now I don't know if the frequency and period of the structure are right. How can I do? Thanks a lot to everyone!
vise92
DennisVDijk
[1] You should add more nodes along the length of the mast and flag pole. use "division" into part, take 15 for the mast and 8 for the pole.
[2] modal settings:
Kind regards,
Dennis van Dijk
Structural engineer
www.ibureaunoordwolde.nl
vise92
Thanks for the reply. Just insert nodes or do I have to divide the segment into several segments? Thanks a lot!
DennisVDijk
Select a bar and use "division"
Kind regards,
Dennis van Dijk
Structural engineer
vise92
Ok! Thanks a lot! I had done so! I came up with these results and comparing them with another program are very different: in Robot I have the frequency of 2.97 Hz, in ProSap I have 1.96 Hz. Same loads and same settings ... Arrived at this point, how do I understand who is giving me the right value? To me honestly 2.97 Hz seems a bit high, doesn't it?
DennisVDijk
your 1st mode shape must be looking like this:
the frequency can be rigth, it depents on the stiffness of the mast and pole.
If you are not sure you can check it by hand calc.
I have attached my model.
Kind regards,
Dennis van Dijk
Structural engineer
