Core walls for lateral stability
marte.oline.bodal
Message 1 of 8
marte.oline.bodal
Hi, I'm trying to make a model where all the lateral stability is located in a central core. I've handcalculated the displacement of the building and my robot answer is quite off... It lookes like som other part are providing stiffening to the building as well, the model is attached.
Replies (7)
Message 2 of 8
Rafacascudo
Zip it before attaching
Rafael Medeiros
Message 3 of 8
marte.oline.bodal
I did  that, don't know why it didn't get attached, but I'll try again 🙂
Message 4 of 8
Rafacascudo
You have many columms ,but all your horizontal force is being resisted by the core wall
Columms are helping with the overturning moment (vertical reactions binary forces
Rafael Medeiros
Message 5 of 8
marte.oline.bodal
Okey, so I've modelled it correctly ? I was expecting the displacement to be around 30 mm.
(I have to do some kind of calculation showing that alle the lateral stability is provided by the core in the model)
Message 6 of 8
marte.oline.bodal
How did you find those reaction forces ? I've tried checking the reactionforces myself, but I get different values.
Message 7 of 8
Rafacascudo
Rafael Medeiros
Message 8 of 8
marte.oline.bodal
Thanks! I tried making the model without the beams, columns and slabs, if the model work the way I want I should get the same maximum deflection as this model, but at the moment I don't get that.
I have modeled the releases of the beams and columns as pinned-pinned, i do not want them to contribute to the buildings stiffness. I want the floor to act as a rigid diaphragm, so that it just transfer the lateral load to the core.
Should I use slab - rigid diaphragm og just rigid diaphragm ?
