Copying in single load cases from excel and they become combinations
daniel.ingman
daniel.ingman
Hi there,
I am copying in load cases from one robot model to another. And when they copy across, they become combinations automatically.
i.e at the end column, where usually it would say 'Static-Linear', it says 'Linear combination'.
Is there a way to stop this?
Muhammed.OPERA
Hi @daniel.ingman
Maybe, you aren't doing it right.
Try Mr. @Rafal.Gaweda 's API Excel file, you can find it here:
https://forums.autodesk.com/t5/robot-structural-analysis-forum/editing-load-cases-in-excel-api/m-p/3...
First, press Import cases/Combinations from Robot while the desired file with load cases is opened in Robot, Then open the file you wanna get the cases inside and back to Excel and press: Generate simple cases in Robot.
Muhammed Mamdouh (OPERA)
Structural Engineer, Instructor
Facebook |LinkedIn
