Copy Walls Bug
Copy Walls Bug
BorislavIvanov
Message 1 of 16
Copy Walls Bug
BorislavIvanov
Hi all,
I am working on a pretty big project - a tower + residential part with a lot of complex modelling (walls with openings, rigid links, etc.).
I've noticed an annoying bug, that occurred the previous week while working on the tower - replicating selected elements (predominantly walls) by using the copy content of the story option (over the selection) copied a lot of other elements (frame elements, slabs, etc) with a random height pattern, which created an enormous mess.
Now the same bug appeared in the residential part of the model (see attached).
Any help would be appreciated.
Borislav
Replies (15)
Message 2 of 16
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @BorislavIvanov
Could you zip and attach the model? Please indicate the numbers of the selected panels.
Artur Kosakowski
Message 3 of 16
BorislavIvanov
Here's the model (see attached).
The list of the elements I am trying to copy is as follows:
234to240By2 241 2978 2979 2984to2987 2990 2991 3020 3021 3028
Borislav
Message 4 of 16
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @BorislavIvanov
I'm not able to tell why internally Robot selects more objects than this list but while it is being investigate I want to indicate the alternative approach which you may find helpful:
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Message 5 of 16
BorislavIvanov
Arthur,
Thanks for your time.
That's pretty much what I did (except for modifying the walls one by one with the contour definition option and deleting the unnecessary bars, which stay selected while using the copy command (this is unfortunately not the case when using copy content of the story option)).
As I corrected the walls and deleted the bars, the bug didn't show again.
Thanks again,
Borislav
Message 6 of 16
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @BorislavIvanov
The initial result of the investigation is that Robot for some reason replaces the numbers of openings defined in the selected walls (which are 'linked' to them) with 'others' which happens to be bars. We will look into it deeper. Thank you for notifying us about this situation.
Artur Kosakowski
Message 7 of 16
BorislavIvanov
Arthur,
Several other bugs occurred as well, the most annoying of which shows the reverse problem - deleting openings deletes other structural elements. Is there any solution for this?
Along with the aforementioned problem, the program seems to crash too often, as well as showed some problems with the load table. However, if I try to open it in repair mode the openings are getting converted into geometrical objects, respectively the walls are getting meshed in the openings areas, which I cannot fix as well.
However, the most important for me now is to be able to delete some of the openings. Any help would be appreciated.
Borislav
Message 8 of 16
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @BorislavIvanov
Could you give me the number of an opening from the model you attached previously which behaves in this way when you delete it?
Artur Kosakowski
Message 9 of 16
BorislavIvanov
Arthut,
I've tried to find a workaround - I isolated the problematic opening and changed the wall geometry so it's now a geometrical object.
See model attached - the number is 5016.
Borislav
Message 10 of 16
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @BorislavIvanov
After opening the model in the repair model I was able to delete the indicated contour without any other objects being affected.
Artur Kosakowski
Message 11 of 16
BorislavIvanov
Arthur,
See attached screenshots - it's still deleting elements on my side.
Borislav
Message 12 of 16
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @BorislavIvanov
Is it the same for 'my' recovered model?
Artur Kosakowski
Message 13 of 16
BorislavIvanov
Arthur,
It works in the recovered model - no elements are getting deleted.
However, all openings seem to be transferred to geometrical objects, which doesn't affect the mesh of the wall - any ideas on how to fix this?
Borislav
Message 14 of 16
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @BorislavIvanov
Which wall shall I look at?
Artur Kosakowski
Message 15 of 16
BorislavIvanov
It's my bad, it seems to work (your repaired model).
I've tried repair several hours ago and it was still deleting elements after the delete.
As I have some progress on the already attached model (a few posts ago), would it be ok if I upload you a model in an hour, so you can repair it again - it seems that your repair works better than mine?
Borislav
Message 16 of 16
BorislavIvanov
Arthur,
Here's the model (see attached). I'd appreciate if you repair this one as well when you have the time.
Borislav
