Copy and paste reinforcement in beam
I'm trying to copy and paste reinforcement into my beam, but I'm getting the following message (as shown in the attached): "an unnamed file has a bad format."
I've successfully copied and pasted reinforcement before in the same model, however after updating some loads and re-running the calculations it no longer works.
Thanks, Joe
Pawel.Pulak
Autodesk Support
Autodesk Support
Solved outside of the forum.
The manual modification of reinforcement resulted in loosing properties of some rebars. It could cause problems when pasting these rebars to other RC elements.
Properties re-built by Copy, Delete and Paste back the reinforcement to the same beam ( Ctrl+A, CTRL+C, Del, Ctrl+V )
If this post answers your question please click the "ACCEPT AS SOLUTION" button (the button visible when logged to the forum). It will help everyone to find answer more quickly!
Pawel Pulak
Technical Account Specialist
