Coordinates for shell forces
kristoffer_perssonXMFUD
Hello
I am new to Robot so sorry if this is basic...
I want to export a list of shel forces to excel.
Is this possible?
Can't seem to link .rtd file ...
Romanich
Hi @kristoffer_perssonXMFUD ,
You can open another table with node coordinates.
Technically this task can be solved using API.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Thanks that works.
Do you now if it is possible to export the information from cuts (located at 1/8, 2/8, 3/8 ... of the span) in the same way? (constant force possiple?)
Romanich
Unfortunately not possible.
https://forums.autodesk.com/t5/robot-structural-analysis-forum/panel-cuts-in-tables/m-p/8463768#M729...
https://forums.autodesk.com/t5/robot-structural-analysis-forum/panel-cuts-in-panels-in-tablature-for...
Roman Zhelezniak
Currently workning on a workaround with modifying the mesh size so it is 1/32 part of the span and then using some of the node values.
I have tried renumbering nodes as explained in:
https://forums.autodesk.com/t5/robot-structural-analysis-forum/change-node-numbers/td-p/3677356
The problem is that this seems to get reset everytime i calculate.
Why does this occur and is it possible to prevent this reset of node numbers?
There seem to be a good system for this with beams....
https://forums.autodesk.com/t5/robot-structural-analysis-forum/table-results/m-p/8796017#M76036
hi @kristoffer_perssonXMFUD
to avoid automatic re-meshing of modifed panels you must freeze their meshing
to align inside nodes at a specific line you can also draw a polyline over the panel
Best regards
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
Thanks, this help so much! @Stephane.kapetanovic
