05:12 AM
Greetings Members,
I have a model , in which I have to check the Column base connections.
In robot, it takes the foundation as Concrete. I had to create a custom material with Steel properties so as to use it.
I have selected the column and its supported node and robot automatically generated a pinned-column base connection type,.
My quiries:
1) Is it okay to model the foundation block as steel plate ?
2) How can I change the pinned-column type to fixed-column type. I want to use more number of anchor rows. In pinned column type, it is hard coded to 2.
