Convergence problem
Convergence problem
Convergence problem
Hi All,
I am modelling the structure attached but keep on getting an error and warning message say it cant converge.
would you please advise.
Please see the structure below
Hi All,
I have been modelling this structure and I am getting a problem with convergence.
Would you please advise.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
You need to remove the excessive releases from the columns and set the full Newton-Raphson method:
I'm attaching such modified model.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Hi Artur Kosakowski
Many thanks for the response and the updated modified model.
Kind Regards
