12:30 PM
Hello everyone,
I have this containment slab on grade that I have modeled with 8" walls all around it except for one section that has steel framing with cladding (Model attached). I tried to run the calculations on it but seem to be getting the following warnings:
- No supports
- Incorrect definition of contour load for the load case 2. Panel no.1
- Incorrect definition of contour load for the load case 4. Panel no.1
- The instability (3 type) in the RY direction in the node 3037.
For point 1., I only have a slab that has a KZ value of 15000 kN/m3. That is the only support so I'm assuming that should not cause any errors in my design?
For point 2. and 4., I'm not sure why there is an incorrect definition of contour load?
Finally point 4. says instability type 3. What is causing this and how should I fix this?
