Connections of two steel beams sitting on each other
mmansourV5MFV
mmansourV5MFV
I would like to ask what is the best way to connect two steel beams sitting on each other along their length?
Many Thanks
Regards
Mohamad
CaioSaporito
Hi @mmansourV5MFV.
You can use rigidlinks connecting each other or use "compatible node" tools (more technical  but more practical approach).
To illustrated see this link:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/ROBOT-how-to-model...
Best regards,
Caio
Simau
I think @mmansourV5MFV  is talking about 2 beams linked like that.
As suggested by @CaioSaporito you may use rigid links along the beams
M. Agayr
mmansourV5MFV
Hi Simau,
You are right I want to use them on each other as you showed in your attached photo.
I'd like to confirm that if I use rigid link, I must block Ux, UX, UZ, RX, RY, and RZ. Because if I only block Uz, the deflection will be different than if I block UX and UZ, especially in truss designs.
Regards
Mo
Simau
@mmansourV5MFV
Correct
Block all dregrees of freedom
M. Agayr
