Connection with robot structural through API
dawid.deptula
dawid.deptula
I create addin in Autocad. I want to connect with Robot Application, which is currently opened and have some bars selected. How to create connection with already opened application?
Stephane.kapetanovic
hi @dawid.deptula
Using Excel, after adding the library as a reference in the VBA editor the code starts like this
Dim RobApp As IRobotApplication
Set RobApp = New RobotApplication
to see example of addins
https://forums.autodesk.com/t5/robot-structural-analysis-forum/useful-addins-for-robot-api/td-p/3899...
Best regards
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
dawid.deptula
Unfortunatelly, when I run Robot File, next autocad with adding and try your solution, my program doesn't see active Robot software. I check Project.Visible parameter and it is 0 value.
hi @dawid.deptula
did you try to reboot ?
dawid.deptula
I don't understand. What you want to reboot?
your computer. after using several connections without sucess it can be done to clear all instances
