CONNECTION DESIGN
CONNECTION DESIGN
CONNECTION DESIGN
how can i add 2 plates instead of 1?
like in this image :
legar
AFAIK it is not possible... and it is pointless.
If You want to use thicker column flange, just use custom welded I section with the same web height and use it as column profile (only in connection design).
The only problem is, that You can use only symmetrical I sections.
You can use I-section with thicker flanges in the model in knee area, but it is not necessary - You can use it only in Connection Design module:
Robot - knee connection with thick flanges.pngRobot - knee 1.pngRobot - knee 2.png Jerzy
legar
Some additional comments to Knee connection design:
  1. Replacing column flange to thicker one... is easy for welded profiles.
  2. For hot-rolled I-sections it is also possible but... a little bit laborious Smiley Wink then in such case, before replacing column flange into thicker - You can try another strengthening methods:
Methods of strengthening columns.pngMethods of strengthening columns - sketches.png
Jerzy
