10:59 PM
I am designing a steel superstructure which consists of steel container type modules. The modules between themselves are welded together in the column places. What would be the best way to model the connection between them if it is a welded steel plate 80x10 mm? If I put a steel section 80x10mm with no releases then after calculation I get type 3 instabilities. Maybe someone has made a steel module superstructure like this and can help me. Attached some pictures.
