**Connection between a reinforced concrete column and a steel section column in Autodesk Robot Structural Analysis
leundee
Message 1 of 1
leundee
Hello everyone,
I am currently working on a composite structure (reinforced concrete + steel) in Autodesk Robot Structural Analysis and I am facing an issue regarding how to define the connection between a reinforced concrete column and a steel column (IPE section), both connected at the same node in the model. I would like to understand how to properly model this connection in order to realistically represent the actual behavior of the joint. Would it be appropriate to consider this node as a pinned connection to simulate a non-rigid behavior, or should a fully rigid continuity be maintained between the two elements? Is there a more suitable approach, such as using releases, springs, or a specific modeling strategy for the connection? My goal is to achieve a consistent and realistic representation of this connection during the analysis phase, and to correctly generate the joint within the software. Thank you in advance for your feedback.
@Guillaume.Chazal , I have seen several of your insightful contributions regarding modeling in Robot. If you have any experience or recommendations on this type of composite connection, your input would be greatly appreciated.
Replies (0)
