Connecting shell structure and steel work
I have exhaust ducting supported on a steel structure and I need some advise on modelling the foot print. currently I have only managed to model the steelwork and the ducting. The ducting will be restrained (fixed) at the top of the steel with support feet and stiffeners and restrained at the bottom by sliding (roller) support feet 6 meters above grade.
thank you for your help
Rafal.Gaweda
Autodesk Support
Autodesk Support
Example of my way (if I understood you correctly):
Rafal Gaweda
That's great,  thank you very much for your help
