Composite slab modelling
I am currenlty modelling an orthotropic slab composed with a trapezoidal plate and supporting steel beams modelled as bars.
- where can i find the mechanical properties of this slab, including the position of the centre of gravity?
- is the slab placed at the centre of gravity or at the geometrical middle line (half the total height)?
- when applying an absolute UZ vertical downwards offset to the supporting beam local coordinate system, is this relative to the orthotropic slab centre of mass, geometrical middle line or other?
Thank you in advance for your assistance.
Tiago
mustafahesenow
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
