Composite section analysis
EY23
Message 1 of 13
EY23
Dear all,
I'm trying to simulate an encased concrete composite section. But the analysis took much time and part of the drawn section were neglected by robot.
Any Ideas?
Replies (12)
Message 2 of 13
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @EY23
Could you attach Robot file and screen captures which explain the situation?
Artur Kosakowski
Message 3 of 13
EY23
@Artur.Kosakowski Thank you for your reply.
Kindly find attached files
Message 4 of 13
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @EY23
You need to redefine the section shape:
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Message 5 of 13
EY23
My section has 2 types of concrete..
the internal beam 14 mpa and the external 30 mpa. in ur case the concrete
type is similar
Message 6 of 13
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @EY23
So it was what was intended but not done exactly as such Smiley Happy
Please change the material of the outer section as 30mpa concrete was not defined in the section you sent therefore I wasn't able to assign it. Mind that the rebars can be of slightly different diameters as well.
Artur Kosakowski
Message 7 of 13
EY23
I tried it but it neglected the bottom rebars- when I cilec in the circles it shows that they are steel. but in the analysis they are neglected as if they are not moved at the top of the facesection-trial 2.png
Message 8 of 13
EY23
Dear @Artur.Kosakowski
When I transfer the section to the modulus the shear Modulus G any suggestions?Shear Modulus.png
Message 9 of 13
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @EY23
Make sure you defined G in the material properties of 14mpa concrete material in Job Preferences before you created the section in the Section Builder module  and that the cuts are at the locations of rebars:
Artur Kosakowski
Message 10 of 13
EY23
@Artur.Kosakowski thank you for your reply.
kindly find attached the pictures showing 3 cases.
My section is made of 3 materials:
-why the Ix and Wx are not calculated?
-G is defined for all types of concrete, why it isn't calculated in the section.
-for the same load Fz for the composite section is larger than the ordinary one the pictures shows
Message 11 of 13
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @EY23
These values are not calculated for the composite sections. You can enter them using the Section Browser in the User Section database based on the results obtained for the concrete section of the same shape.
As the final section properties are weighted based on E of the composite section components assigning the corresponding G value is not possible. On the other hand its influence would be only visible if you include shear in the deformation which you usually don't for ribbed slab.
As the composite beam is more rigid than the 'standard' one it 'attracts' more load from the slab. Compare the deflection of both beams.
Artur Kosakowski
Message 12 of 13
EY23
I Have also one last question. Is there any way to reduce the stiffness of the composite beam in the model in order to get more realistic results regarding deflection? (0.35 Ig for beam)
Message 13 of 13
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @EY23
The only way I can think of is to edit its Iy value in the section database.
Artur Kosakowski
