Composite RC-Steel section
Tuctas
Tuctas
Are we able to analyze a composite section consisting of a R.C and a Steel section in the Section builder module? (e.g a section like the one in the attached picture). Can reinforcement bars be adequately modeled/analyzed?
Regards
Artur.Kosakowski
Autodesk Support
Autodesk Support
If you mean according to EC4 then this option is not available in RSA. If you want to check stress distribution (assuming elastic behavior of concrete) in the stress analysis module then yes.
Artur Kosakowski
Tuctas
Thank you for the answer Artur.
Yes, that is what i meant (the presentation of stress distribution assuming linear behaviour of concrete).
Do you think that we will be able to obtain the generated forces applied on rebars effectively (according of course to the above assumption about linear behaviour)?
Artur.Kosakowski
Autodesk Support
Autodesk Support
I think that you can determine value of stress in a given point and then convert it into force.
Artur Kosakowski
Tuctas
O.k Artur,
Thank you for the answer.
Regards.
