06:46 AM
I have two models with identical geometry, but varying support conditions and material properties. One is fixed base static analysis, and the other has spring supports to base and sides and is a modal analysis. Is it possible to combine force resultant results from the two models within Robot, whether they are in the same file (if this is even possible) or within two separate files?
