Combinations
Combinations
endritlloga
Combinations
endritlloga
Community Visitor
Community Visitor
Hi everyone!
I have defined wind loads as load cases.
And when I do automatic combinations, the software
does not combine them. Everything else seems as expected.
What can be the problem. Using EN-1990.
Simau
Hi @endritlloga
Difficult to say without the model
Zip it before attaching
M. Agayr
endritlloga
Community Visitor
Community Visitor
I Found the problem. You cant use groups to define relations on wind loads on Robot. You must define them in the relations tab using parenthesis. Not sure why, autodesk should try and fix that.
