We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
Columns calculation
Columns calculation
faisal.aaouatif
Message 1 of 11
Columns calculation
faisal.aaouatif
would the message in the attachement mean that the calculations with bending are concidered or not ( regarding the the ligne just above )
Replies (10)
Message 2 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
This means that bending has not been take into account for fire resistance calculations.
Artur Kosakowski
Message 3 of 11
faisal.aaouatif
Ist there any reason for that or is it a limitation to the current version of the software ?
Is all the warnings appearing between two message numbers are only relative to the firt one ?
thank you
Message 4 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
What is the design code you selected?
Could you send me this example?
Artur Kosakowski
Message 5 of 11
faisal.aaouatif
Calculation option  BAEL91 mod99 Regulation BAEL91RPS2000.
having a a problem with my model : connot generate ULS and SLS combinations ( only ACC are generated ! ).
thanks for support
Message 6 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
Send me the rtd file please.
Artur Kosakowski
Message 7 of 11
faisal.aaouatif
ok , not managed to upload to autocad360 , please find a link blelow :
http://wtrns.fr/pnjYq_8Zq2Vdmr
thanks
Message 8 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
You have to define relations among load cases (see the attached picture)
Which RC column shall I look at?
Artur Kosakowski
Message 9 of 11
faisal.aaouatif
Exporting the column 727 for example
Message 10 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
The warning informs that the estimated method for fire resistance is not applicable for bending. It can only be used for compression and slenderness below 35 as stated in DTU P 92-701.
The exact method for bending is not available in Robot yet as far as I know you the freeware named CIMFEU for this kind of calculation is available from:
CIMbéton
7, Place de la Défense
92 974 Paris-La-Défense Cedex
+33 (0) 1 55 23 01 12
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 11 of 11
faisal.aaouatif
Clear and precise.
Thank you for all
