Column with variable cross-section
I'm about to design a 10 meter steel cantilever column with variable cross-sections. I don't know what method should I use. Am I suppose to  build different cross-section column and make a superbar out of it, or gradually biuld my way from the bottom ? I have a problem with slanderness and how to deal with it due to changing cross-sections. How should I deal with that properly? Thank you for your answers.
EduardoMeruvia
Hi @Anonymous,
Have you look into using the custom tapered section tool in robot? See figure below; Tapered Section.PNG
This tool allows you create variable cross-section sections of different kinds.
Hope this helps.
The problem is not how to create such column, but how to obtain correct results. Cross-section doesn't change gradually but like this:
When I create a superbar it gives me results only for one section of a column. But it is the most strenuous one. So it is possible to check every bar, however I find it very unconvinient. Node shift can be only 10cm. I obtained result such as: 5m- round pipe 273x10; 2,5m- round pipe 193,7x6,3; 2,5m- round pipe 168,3x5. The node shift is 10cm, and there is no problem with slanderness and ULS. My question is: does this profiles have to be this big, or am I doing some mistake ?
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
You should create a superbar but bear in mind that the results are shown only for a location where the calculated ratio is the highest. If you want to see what they are for another places check this article.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Is it still possible to read the article? Page is not found.
