Column Reinforced Italian NTC 2008
andrea_pontiggia
andrea_pontiggia
I can not understand this message:
at which point I have to read the rules?
thanks
Andrea
Rafal.Gaweda
Autodesk Support
Autodesk Support
File please.
Rafal Gaweda
andrea_pontiggia
Here's the file.
http://we.tl/sjjwfhcLsT
Tthanks
Andrea
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi Andrea,
I'm sorry but I'll need a bit of time to check this.
Artur Kosakowski
Artur.Kosakowski
Autodesk Support
Autodesk Support
Artur Kosakowski
Artur.Kosakowski
Autodesk Support
Autodesk Support
In RSA 2017 the error displays additional references to the corresponding paragraph of the code:
Calculations of attached column give warning: column's width =30cm does not satisfy the rule >=30.1(cm).
for DM2008:
(DM 14/01/2008, 7.4.6.1.2)
for EN8:
(EN 1998-1:2004, 5.2.3.7 (2)P a))
Artur Kosakowski
