Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Code combination regulations
10 REPLIES 10
Message 1 of 11
HenkaCarlsson
534 Views, 10 Replies
I'm trying to add a live load with the subnature "crane" to the combination regulations.
But it's not working when I'm trying to generate the manual combinations. If I exclude this new type of live load the combinations is genereted but not if it's included.
Is it some limitation that makes it impossible to do this or am I doing something wrong?
10 REPLIES 10
Message 2 of 11
Your rgl file please.
Rafal Gaweda
Message 3 of 11
Here it is.
Message 4 of 11
Nope, no file. Try harder 🙂
Rafal Gaweda
Message 5 of 11
One more try....
Message 6 of 11
Message 7 of 11
Message 8 of 11
To be sure that you are loading correct regulation please change regulation name.
I did it and I see :
Rafal Gaweda
Message 9 of 11
I did that and the it's working with the manual combinations but not with the manual combinations generated automatically. It would be a big help if that worked because it is a lot of combinations..
Message 10 of 11
Please check again.
This is what I see:
Rafal Gaweda
Message 11 of 11
I redefined the loads as "Crane" loads, deleted the load groups and relations and redefined them and now it worked.
Thank you. 🙂
