Cladding warnings
Cladding warnings
Cladding warnings
Good afternoon,
I`m having problems with a very simple model created in Autodesk Robot.
I created claddings as always but it gave me two warnings:
  • Faces (the objects without assigned thickness) not used in solid area generation. FE mesh has not been generated
  • The load has not been distributed correctly – there are no objects or elements carrying the load overlap
I delete the panels and re-created them but I still get these warnings.
Do you know how to fix it?
Model attached.
khimpitou
1. Cladding no load to generated
2. Make sure the load aplied ( attached) to cladding and no cladding contour overlap at the point of applied load
Yes yesterday I applied the loads and the two warnings were gone. No mistakes on overlapping cladding or something else.
Anyway no sense at all that you get these two warnings.
I usually run the model before applying the loads to see if the geometry is correct and if I get warnings or errors I fix them before losing time on applying loads.
khimpitou
It just warning because rsa curious  what you actually wonna do !
